Transfer/Connect with the carrier through IPCC
Answered Question
Mar 27th, 2008
I have a customer who needs to use transfer connect in the script with AT and T. They have set up *8 to transfer the call to the outsourcer and disconnect the original call. I tried using the "Call Consult Transfer" step with the outsourcer as the destination and "*8" as the output digits.
Correct Answer by pklos about 8 years 10 months ago
It is Send Digit String Step in Media Steps branch.
regards,
PK
Overall Rating: 5 (1 ratings)
pklos Thu, 03/27/2008 - 10:22
Try generate DTMF instead doing transfer.
regrads,
PK
Correct Answer
pklos Thu, 03/27/2008 - 15:48
regards,
PK
cmbhelpdesk Fri, 03/28/2008 - 06:20
Thank you, very helpful. One more question. Would i use a "Call redirect" step next to answer this or would I use the "place call" step.
pklos Fri, 03/28/2008 - 06:36
I'm not sure, I think consult transfer should be OK. Please describe you desired call flow.
regards,
PK
