ASA5520 VPN Monitoring
Answered Question
Mar 27th, 2008
I have just moved from 2 VPN 3015 Concentrators to 2 ASA 5520s. Under Monitoring I was able to see the VPN client Versions that were connected on my 3015 Concentrators but on the ASA 5520s, when I go to Monitoring > VPN >VPN Statistics > Sessions the "Client(Peer) Type Version" column is blank. Any configuration I need to get the verisons to display?
Correct Answer by JORGE RODRIGUEZ about 9 years 3 months ago
Craig,
I am not aware of any additional config required for that particular field Client(Peer)Type version field to show up, at least I do not recall additional settings but I will double check, I run 8.0.3 and do see all of my ra vpn clients type peer type version information, I would not think this could be additional settings as the whole line is part of the vpn monitoring session but again I take a double look, do you get other session information fine such as username, group policy,protocol encryption type etc.. what version of code are you running both asa and asdm.
Rgds
Jorge
Overall Rating: 4 (2 ratings)
Correct Answer
JORGE RODRIGUEZ Thu, 03/27/2008 - 15:57
  • Green, 3000 points or more
Craig,
Rgds
Jorge
Sighclops Fri, 03/28/2008 - 05:06
Yes I get all other Information. It is only the Client(Peer)Type Version which is blank.
ASDM 6.0(2)
ASA 8.0(2)
Possibly a fix in the ASA 8.0(3)?
Sighclops Fri, 03/28/2008 - 05:35
Hi Jorge,
I beleive the move to 8.0(3) will correct the issue.
CSCsj34537
Yes
ASA 8.0 show vpn-sessiondb detail remote does not show client version
I actualy thought I had the latest version of ASA. thanks for the kick in the right direction.
JORGE RODRIGUEZ Fri, 03/28/2008 - 09:15
Craig, nice findings, thank you for sharing this information..
