BACD CME/SRST
paolo bevilacqua Thu, 03/27/2008 - 07:05
  • Hall of Fame,
    Founding Member
Hi, begin with "debug voice application script". You will see if the script is kicking in, and any obvious error.
Note: 12.4(15)T in general are quite buggy for CME. Suggest you go with 12.4(11)XJ4 that is know to be stable.
Thanks for the reply. It doesnt look lik the script is kicking. I was wondering which aa tcl I need the one forsrst or for cme? Do I need to use the loopback address?
I also out the config onto a gateway running cme and it worked.. the show applications doesnt even show the ques tcl as being active. I know the aa will not show in the sessions command till a call hits it but the que tcl does. I will try the ios..
I just hvent seen anyone use bacd with CME running in SRST mode and wonder if that is the issue
Thanks again
paolo bevilacqua Thu, 03/27/2008 - 08:01
  • Hall of Fame,
    Founding Member
ASAIK, there is only one script. When the script doesn't kick that is due to DP pots misconfiguration, you might be missing "incoming called-number".
You do the loppback interface and voip DP only to get the service from IP phones.
Here i my config th bacd stuff
service aa flash:app-b-acd-aa-2.1.2.2.tcl
paramspace english index 1
param number-of-hunt-grps 1
param handoff-string aa
param dial-by-extension-option 3
paramspace english language en
param max-time-vm-retry 2
param max-extension-length 4
param aa-pilot 1020
paramspace english location flash:
param second-greeting-time 60
param welcome-prompt en_bacd_welcome.au
param call-retry-timer 15
param max-time-call-retry 60
param voice-mail 6000
param service-name cq1
service cq1 flash:app-b-acd-2.1.2.2.tcl
param queue-len 3
param aa-hunt1 1010
param queue-manager-debugs 1
voice translation-rule 5141017
rule 1 /^5147642886/ /1020/
voice translation-profile Test
translate called 5141017
dial-peer voice 516784 voip
description Send Call to CME-BACD
translation-profile incoming Test
preference 1
destination-pattern 516784....
voice-class codec 1
dtmf-relay h245-alphanumeric
dial-peer voice 1010 voip
service aa
destination-pattern 1020
session target ipv4:10.10.46.15
incoming called-number 1020
codec g711ulaw
no vad
paolo bevilacqua Thu, 03/27/2008 - 13:45
  • Hall of Fame,
    Founding Member
Try:
application
service aa
param welcome-prompt _bacd_welcome.au
then as mentioned "debug voice application script" can guide you further.
It really looks like if the router switches to cme./srst mode it doesnt work. If I config it in a lab it works fine but taking a working config and putting it on the production router and force it to srst mode it fails..
PDI Help says BACD riunning is CME/srst mode is not supported but I am not sure..
I have verified that he audio file works but I will tr using the wav that comes in the bacd package.
Thanks for the replies
