multicast issue in a VLAN in Catalyst 3750
Mar 27th, 2008
How do i enable multicast traffic into a VLANs from other VLANs ?
I have configured point-to-point routed links between 2 catslyst 3750 switches.
(multicast source)VLAN 10 ----Routed link-----> VLAN 11 (multicast destination)
I have enable:
ip multicast-routing distributed
My VLAN interface config is as follows:
Switch A
interface Vlan10
ip address 10.41.10.254 255.255.255.0
no ip redirects
ip pim sparse-dense-mode
no ip route-cache cef
no ip route-cache
no ip mroute-cache
Switch B
interface Vlan11
ip address 10.41.11.254 255.255.255.0
no ip redirects
no ip route-cache
no ip mroute-cache
Is it workable ?
Harold Ritter Thu, 03/27/2008 - 07:49
I would rather configure "ip pim sparse-mode" on the two vlans and then configure the 3750 as the RP. Otherwise, the multicast data could be flooded to vlan11 even if there is no one interested to this traffic on this vlan.
melwongpl Thu, 03/27/2008 - 08:00
Thanks for the reply.
In fact to make it clearer, there will always be multicast traffic in both of these VLANs.
I have tried it out in my lab, but i am unable to receive any multicast. What could be an issue ?
What does no ip mroute-cache meant ?
frederic.lemair... Mon, 11/23/2009 - 11:55
you have to put the pim configuration ( ip pim sparse-dense-mode or ip pim sparse) on the 2 side's L3 interface between your 2 3750.
you should so have something like these on your first 3750 :
int vlan xxx
int gi1/0/1 --> L3 to second 3750
ip address 172.16.18.1 255.255.255.0 for exemple
and on the second 3750
int vlan yyyy
int gi1/0/1 (L3 to first 3750)
ip address 172.16.18.2 255.255.255.0 for exemple
if you want to use sparse mode, you need to configure RP ( auto-rp or manual RP).
Regards.
