Command To Show Date
dianewalker
What is the command to show date on the AS/5300?
Thanks.
Diane
pciaccio
Level 4
Level 4
The SHOW CLOCK command will show you the date and time set on the AS5300....
Thanks for your quick response. When I typed SHOW CLOCK, it displayed
22:06:21.188 UTC Fri Feb 4 2000
We are in PST (Pacific Standard Time). Today is 3-27-08. The time is about 1:20 pm. Does "Show Clock" show the correct date and time? Thanks.
The time of a device can be manually set or set with the use of the NTP protocol clocking off a master timing device. In your case you may need to manually set it with the command CLOCK SET command. From there you can set the date/time of the AS5300. If your network devices are all timing off one source then you may want to set your AS5300 to time off the same source. Use the NTP command to set up your parameters. You can go to the following URL for help on the subject...
http://www.cisco.com/en/US/docs/switches/lan/catalyst4000/7.6/configuration/guide/ntp.html
Good Luck...
