Alternate Route
Rick Morris Thu, 03/27/2008 - 12:02
  • Silver, 250 points or more
are you running the 3550 in layer 3?
meaning do you have ip routing turned on?
sundar.palaniappan Thu, 03/27/2008 - 12:23
  • Green, 3000 points or more
Simon,
There's a feature called reliable static route using object tracking and this can provide the redundancy you are looking for. You can point the route on the 3550 to the primary PIX and the second route, with a higher administrative distance, needs to point to the redundant PIX. The object tracking feature would verify the status of the primary PIX and if it goes down the 3550 would start using the redundant route.
Here's a link that can help you understand and configure this solution. Let us know if you have any questions concerning this.
http://www.cisco.com/en/US/docs/ios/12_3/12_3x/12_3xe/feature/guide/dbackupx.html#wp1066247
Sundar
Rick Morris Fri, 03/28/2008 - 08:16
do you have any routes configured?
is it possible to post the config?
