Server in DMZ
Mar 27th, 2008
Hi I am a beginner of ASA (8.0). I setup a ASA for device upgrade. I want to set up servers in DMZ. Unfortunately, I found that I can't access Server (in DMZ) from inside interface, for example, web access or ping test
I am checking it for long time and add the following commands but the problem is still exist.
#access-list DMZ_access_in extended permit ip
#access-group DMZ_access_in in interface DMZ
static (inside,DMZ) netmask
Anyone give me a help??
I attach my config
acomiskey Thu, 03/27/2008 - 09:50
This should do the trick
access-list DMZ_access_in extended permit icmp
You don't need to permit ip in the acl for traffic originating from the inside.
Jesse Wiener Thu, 03/27/2008 - 09:49
I do not see the static in the config that you sent, but the one in your post has the wrong ip's.
Should be static (inside,DMZ) netmask
acomiskey Thu, 03/27/2008 - 09:51
will work fine.
logintck Sun, 03/30/2008 - 07:18
Thank you all of you. I fix the issue according the recommentation
