Issues accessing ASDM on ASA platform
Mar 27th, 2008
Last night I upgraded our ASA 5510 platforms from 7.0 code to 7.2 code.
I also shipped the new ASDM image to Flash (5.2.3).
this morning I wanted to access the ASDM launcher,so I navigated to https://<address of ASA>. I attemtps to authenticate me to the box, but then I get "Page cannot be displayed".
I can perform a sho disk0 and see both the old ASDM image and the new ASDM image and was curious if this might be causing the problem.
Do I need to delete the old ASDM image?
Overall Rating: 5 (1 ratings)
allanc_16 Thu, 03/27/2008 - 09:14
can you post the output of the following command?
show run http
Kevin Melton Fri, 03/28/2008 - 06:55
bhiasaip# sho asdm image
Device Manager image file, disk0:/asdm506.bin
bhiasaip# sh flash
-#- --length-- -----date/time------ path
6 5474304 Dec 31 2002 19:04:50 asa706-k8.bin
7 5823980 Jul 21 2007 03:11:10 asdm506.bin
10 8386560 Mar 26 2008 18:59:00 asa723-k8.bin
11 0 Mar 26 2008 17:30:20 crypto_archive
12 6287244 Mar 27 2008 01:54:48 asdm-523.bin
229367808 bytes available (26058752 bytes used)
bhiasaip# sho ver
Cisco Adaptive Security Appliance Software Version 7.2(3)
Detected an old ASDM version.
You will need to upgrade it before using ASDM.
Compiled on Wed 15-Aug-07 16:08 by builders
System image file is "disk0:/asa723-k8.bin"
Config file at boot was "startup-config"
bhiasaip up 1 day 7 hours
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is 001b.54ab.18f6, irq 9
1: Ext: Ethernet0/1 : address is 001b.54ab.18f7, irq 9
2: Ext: Ethernet0/2 : address is 001b.54ab.18f8, irq 9
3: Ext: Ethernet0/3 : address is 001b.54ab.18f9, irq 9
4: Ext: Management0/0 : address is 001b.54ab.18fa, irq 11
5: Int: Not used : irq 11
6: Int: Not used : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 50
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : 250
WebVPN Peers : 2
This platform has a Base license.
Serial Number: JMX1129L12S
Running Activation Key: xxx
Configuration register is 0x1
Configuration has not been modified since last system restart.
Well those commands answered alot indeed. I noticed at the end of the sho ver that it indicated that "the platform has a bad license". Why would it indicate that?
Kevin Melton Fri, 03/28/2008 - 06:51
http server enable
http management
http inside
The inside address is the address of my workstation at the customer site...
francisco_1 Thu, 03/27/2008 - 09:39
have you tried booting asa with the new asdm?
asa(config)asdm image flash:filename.bin
francisco_1 Thu, 03/27/2008 - 09:41
your asdm can be in flash but if you dont tell the asa to use it, it wont until you instruct it to use it.
Kevin Melton Fri, 03/28/2008 - 06:58
that being said, is there any issues with going ahead and using the command you had previously recommended which was:
asdm image flash:asdm-523.bin
and then doing a "wr mem" so that during the next restart, it will reference the correct image?
Thanks again for your assistance.
Kevin Melton Fri, 03/28/2008 - 06:49
Have not tried to boot using the new ASDM image. I will have to schedule this to happen at some point, since it guards the customers DMZ and Production networks from the Outside.
Would the command be
asdm image disk0:asdm-523.bin vs. flash??
thanks for your input
