03-27-2008 08:57 AM - edited 03-13-2019 05:07 PM
Is there a special code to use the intercom feature on our IP 7961 phones?
03-27-2008 09:21 AM
it would be really helpful if you tell us what you're using.
CUCM or CME and version
javalenc
03-27-2008 10:06 AM
We are using CME. I think the version is win-k9-1_5(0.37).
03-27-2008 12:26 PM
There is not a special code, but you cam make tje intercom feature only diable from specicif phones.
ephone-dn 1
number 1000
ephone-dn 2
number 1001
ephone-dn 10
number A1010
intercom A1011
ephone-dn 11
number A1011
intercom A1010
ephone 1
button 1:1 2:10
phone 2
button 1:2 2:11
With this cofig, only ephone 1 and 2 can intercome each other.
Drop the "A" from the intercom ext, then the number can be globally dialed.
There are other configs, but these are the basics.
03-27-2008 01:08 PM
Thank you for the response. Do you need to config this through the Config Assistant or can this be done on the phone itself?
