database timeout
mymite060708
I have a database set up on a remote server. I have set up the database subsystem and configured the script to access it. This all works fine.
I am testing fail over and if I close the connection to the database and the subsystem goes out of service no matter which timer I adjust the script will try and connect to the databse for 45 seconds before going to the No connection error. does anyone know where I can reduce this timer?
thanks
sbilgi
Level 5
Level 5
This could have something to do with the high CPU utilization. Try to update/delete after CPU usage is within 10% and check if it works fine.
telcorinc
mymite, I'm looking for a script that is similar to yours (one that accesses a database).
I'm fairly new to IPCCX scripting and was wondering if you could attach your script in here so I could see how you set up your configuration. Thanks!
James
malinovskiy
Hello, mymite060708!
I have absolutely the same problem with my Database Script.
Please tell me, have you find any solution?
