Need to get a Call count
Mar 27th, 2008
I need to see how many calls we are receiving and the only way I know how to is to run a debug command. We are using Call Manager 4.2. Is there any way to do it without watching the debug command run?
paolo bevilacqua Thu, 03/27/2008 - 10:30
  • Hall of Fame,
    Founding Member
If running h.323 with the CM, "show dial-peer voice" would tell you this and more more informations.
pklos Thu, 03/27/2008 - 10:34
  • Silver, 250 points or more
Connect to CCM's MSSQL server by Enterprise Manager or Query Analyzer. Then choose CDR database and look into CallDetailRecord table, there should be information about all calls in your cluster.
Some more info about CDR:
http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucm/cdr_defs/4_x/cdr412.html
http://www.cisco.com/warp/public/570/avvid/voice_ip/cm_cdr/cm_cdrfaq.html
regards,
PK
