SNMP strings and Passwords
Answered Question
Mar 27th, 2008
I've looked through the online help and cannot find where it shows what strings (RO/RW) are required to perform which function. For example: Is the R/O string used to discover devices or is the R/W string used. Are the Telnet credentials used to archive configs. What is tftp used for...etc.
Is there are list of credentials and their use somewhere?
Correct Answer by Joe Clarke about 8 years 7 months ago
All of this is done using SNMP read-only credentials.
Overall Rating: 5 (2 ratings)
Joe Clarke Thu, 03/27/2008 - 13:06
I do not know if such a list exists. However, as a rule, the read-only credential is used as much as possible. The read-write credential is used only when snmpset operations are required. Therefore, discovery uses the read-only credential. Archiving configs requires an snmpset to trigger the TFTP download, so the read-write credential is used there.
When it comes to whether or not config archive will use telnet or TFTP, that depends on your protocol order configured under RME > Admin > Config Mgmt > Transport Settings.
sirbaughmf Fri, 03/28/2008 - 04:21
Great info, now one more...
When data collection occurs and collects user tracking information, i.e. client IP, Hostname, Mac, etc...what credentials are used, snmp r/w?
Correct Answer
Joe Clarke Fri, 03/28/2008 - 09:45
