NIL Remote Labs
Mar 27th, 2008
Hi there, just looking for some advice regarding the NIL labs i've been reading about - http://www.nil.com/C1256F620032CACB/NILLookup/LB_RL_CCENT?Open&dm=&s=0&rid=C1256F0A00429755.
I'm on the last chapter of my CCENT Cisco Press book and want some decent training materials for some hands on experience. I've done the labs in the cisco prep centre with out any problems! I was thinking of purchasing some kit from ebay for £300 until i saw the NIL remote labs. The CCENT NIL lab covers the list below and it looks interesting, has anybody used these materials?
Garry
Use Telnet and WireShark packet sniffer applications
Use the ipconfig, ping, arp commands
Restart the switch and verify the initial configuration messages
Complete the initial device setup on the Catalyst 2950 switch
Secure the access to the switch
Start the Cisco router and verify the startup messages
Use setup to configure the minimum parameters for router operation
Secure the access to the router
Explore context-sensitive help on a Cisco router
Edit incorrect commands in the router CLI
Examine the router status using the show commands
Modify a running and startup router configuration
Use Cisco Security and Device Manager (SDM) to configure DHCP functionality and Internet connectivity
Configure a serial interface on the router
Conect router to multiple locations
Configure static and dynamic routing
Use CDP to discover the local workgroup network from the switch and router
Determine the storage location of the Cisco IOS image
Copy a configuration from a TFTP server to the startup configuration on a Cisco router
