Command: dot1x pae authenticator
Mar 27th, 2008
I copied a configuration with tftp on switch 2960.
In each interface, the commande "dot1x pae authenticator" dosen't copied.
I precese that in some switch my command has succeed and other don't succeed.
thank you for help
Thank you fpr help
darrenj Thu, 03/27/2008 - 16:05
Hey there. Before we delve into the configuration, is the switch using the same software as the device whose config you are trying to copy?
Darren
CCIE#20078
amirovic13 Thu, 03/27/2008 - 16:35
Can you show me the configuration, to copy the IOS from a switch to another ?
Thank you
