ACS 4.1 and VMWare ESX Servers
A while back, we had some issues with our ACS servers running on VMWware ESX. We've since upgraded ESX to 3.5 and I was wondering if there are any further problems?
We're running ACS 4.1.(1) Build 23 Patch 3 on ESX 3.5.
The reason I ask is because we're in the process of bringing Cisco Works LMS 3.0.1 online in parallel with our 2.6 and are having some issues integrating with ACS.
When LMS does the Verification process we get the following:
Primary ACS Verification Status (acs1)
Tacacs+ Connectivity : Reachable
HTTP/HTTPS Connectivity : Reachable
AAA Client : Not Configured
Secret Key Verification : Not Applicable
System Identity User : Not Applicable
Secondary ACS Verification Status (acs2)
Tertiary ACS Verification Status ( acs3 )
AAA Client : Configured
Secret Key Verification : Success
System Identity User : Not configured properly for - (cwhp,cwportal,CiscoView,rme,CM,dfm)
ACS 1 and 2 are both running on VMWare ESX 3.5 servers
ACS 3 is on real hardware
ACS1 replicates down to 2 & 3 but not visa/versa.
When we were on a older version of ESX we had problems running jobs so we moved our current LMS 2.6 install to ACS3. However, ACS 1 and 2 both have the CW information registered.
Any thoughts as to what the problem could be? Are there still issues with CW and ACS while ACS is running on VMWare ESX?
cisco24x7 Thu, 03/27/2008 - 13:52
  • Silver, 250 points or more
I am running VMWare ESX 3.5 on a Dell 1850
dual Xeon processors with 12GB RAM.
on the ESX Servers, I am running Checkpoint
Provider-1 NGx R65 as an instance
I also have another instance of Win2003 SP2
and I have ACS 4.1(1) build 23 patch 3.
I have another instance of Win2003 SP2 running
RSA SecurID
I have another instance of Redhat Linux ES 3
running Steelbelt radius
All the integration works fine with VMWare
ESX.
I think the integration you have has to do
with Cisco Products integration and not VMWare
ESX.
CCIE Security
When I go through the integration piece, LMS checks the credentials, NDG, Local admin etc. However when it runs this check against a ACS server on VMWare it fails 90% of the time. however when I run against an ACS serve on real hardware, it succeeds 98% of the time.
Any assistance would be very helpful.
simon
