Configuring a Frame-Relay CIR
Mar 27th, 2008
I'm currently a student in CCNP and in my troubleshooting class we have to configure a CIR of 256kb over a frame-relay link. The topology is a strandard triangular shaped 3-router mesh. 2 PVCs, the central router has a multipoint sub interface while the two others are P2P. this is what I configured:
map-class frame-relay CIRMAP
frame-relay cir in 256000
frame-relay cir out 256000
on the interface:
frame-relay map CIRMAP
then I use the command:
show frame-relay pvc X
Only half the usual output appears and nothing is mentionned relating to the CIR.
What am I doing wrong?
Edison Ortiz Thu, 03/27/2008 - 17:17
  • Hall of Fame,
    Founding Member
You need to enable traffic-shaping.
On the hub's main interface enter the following command:
frame-relay traffic-shaping
and under the subinterface
frame-relay interface-dlci [dlci]
class CIRMAP.
Then, you can do the show frame-relay pvc X command.
HTH,
__
Edison.
