Best stable IOS to support OSM-2OC48
Mar 27th, 2008
Now that I know IOS SXH and SXH1 will not support OSM devices, I was wondering if anyone can suggest the best stable IOS to support the OSM-204C49 device.
The highest Cisco safe harbor for the 12.2(18)SXF train is 12.2(18)SXF11. The
highest SXF train is 12.2(18)SXF13a.
Any help would be appreciated
Edison Ortiz Thu, 03/27/2008 - 17:50
  • Hall of Fame,
    Founding Member
What's the problem with using SXF11?
__
Edison.
rlortiz Thu, 03/27/2008 - 17:57
Edison,
I think SXF11 would be fine, too. I just wanted to ask the question, to confirm that there wasn't another version that may be better.
Edison Ortiz Fri, 03/28/2008 - 06:48
  • Hall of Fame,
    Founding Member
SXF11 should do just fine.
HTH,
__
Edison.
