ip route-cache flow- netflow? FastSwitching? Both?
Mar 27th, 2008
Does 'ip route-cache flow' both disable netflow collecting AND fast switching on 2800s or not that cef is everywhere is it only a netflow related command?
Thank you.
Overall Rating: 5 (1 ratings)
Edison Ortiz Thu, 03/27/2008 - 17:21
  • Hall of Fame,
    Founding Member
ip route-cache flow is strictly a NetFlow command however, disabling ip route-cache will automatically disable ip route-cache flow.
HTH,
__
Edison.
jdevoll Thu, 03/27/2008 - 19:46
Thank you for your post, I have one item I need clarified. Is the 'ip route-cache flow' statement functionally equivalent to the 'ip flow ingress'? As near as I can tell, they are. I'm just looking for a sanity check on this one.
Thank you.
Edison Ortiz Fri, 03/28/2008 - 06:45
  • Hall of Fame,
    Founding Member
http://www.cisco.com/en/US/docs/ios/12_3/switch/command/reference/swi_e1.html#wp1112275
Usage Guidelines
If you configure the ip flow ingress command on a few selected subinterfaces and then configure the ip route-cache flow command on the main interface, enabling the main interface will overwrite the ip flow ingress command and data collection will start from the main interface as well as all the subinterfaces. In a scenario where you configure the ip flow ingress command and then configure the ip route-cache flow command on the main interface, you can restore subinterface data collection by using the no ip route-cache flow command. This configuration will disable data collection from the main interface and restore data collection to the subinterfaces you originally configured with the ip flow ingress command.
In short ip route-cache flow can only be used on main interfaces while ip flow ingress can be used on main and sub interfaces.
HTH,
__
Edison.
