Guest Access with a 1240AG
Answered Question
Mar 27th, 2008
I have a 1240AG connected to a 3560 connected to a ASA5505 securtiy plus.
I can not get the vlans to work correctly. Only one SSID will work at a time and only when it is connected to the native vlan.
I have attached my configs
Correct Answer by mirek.tichy_2 about 9 years 1 month ago
Hi, you have a mismach in native VLAN config. I suppose, that VLAN 1 is for the management and VLAN 20/30 are for users.
So firstly - make interface FastEthernet0.1 to be native and Fa0.20 to be taged by 20 and bridge-group 20. BVI 1 will be automatically connected to Fa0.1 and to the VLAN 1 on the switch.
Secondly - the same on interface Dot11Radio X.20. Dot11RadioX.1 can be removed.
Overall Rating: 5 (1 ratings)
Correct Answer
mirek.tichy_2 Mon, 03/31/2008 - 02:17
Trending Topics - Security & Network
