03-27-2008 05:30 PM - edited 03-05-2019 10:01 PM
i have a switch that i cant ping from my pc which is on a 172.16 subnet - the switch is on a 10.10 subnet. i can ping from my router and telnet which has both interfaces directly connected (172 and 10)- i can ping through the switch to a server directly connected. i removed the acl from line vty 0 4 and still no luck.
ill attach the config.
NOC-sh run
Building configuration...
Current configuration : 4355 bytes
version 12.1
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug uptime
service timestamps log datetime localtime show-timezone
service password-encryption
service sequence-numbers
hostname NOC-
username privilege 15 secret xxx
clock timezone MST -7
clock summer-time MDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
ip subnet-zero
no ip domain-lookup
mls qos map cos-dscp 0 8 16 26 32 46 48 56
mls qos min-reserve 5 170
mls qos min-reserve 6 10
mls qos min-reserve 7 65
mls qos min-reserve 8 26
mls qos
spanning-tree mode pvst
interface FastEthernet0/1
description SQLSRV3
switchport mode dynamic desirable
no ip address
duplex full
speed 100
interface GigabitEthernet0/2
description WEBSRV3
no ip address
interface Vlan1
ip address 10.10.11.5 255.255.255.0
interface Vlan10
no ip address
ip default-gateway 10.10.11.2
ip classless
ip http server
ip access-list standard TELNET
remark ACL for TELNET
permit 172.16.0.0 0.0.255.255 log
permit 172.17.0.0 0.0.255.255
permit 172.19.0.0 0.0.255.255
permit 172.21.0.0 0.0.255.255
permit 10.10.0.0 0.0.255.255
deny any
logging 172.16.1.31
snmp-server community md0530 RO
banner motd ^C Unauthorized Access Prohibited ^C
line con 0
exec-timeout 0 0
login local
line vty 0 4
access-class TELNET in
login local
length 0
line vty 5 15
no login
ntp clock-period 17180504
ntp server 207.234.209.181 key 0 prefer
end
thanks.
Solved! Go to Solution.
03-27-2008 05:35 PM
So the switch has a default gateway of
What's the default gateway on your PC ?
Can the default gateway the switch is using ping your PC ? Can the PC default gateway ping the switch?
__
Edison.
03-27-2008 05:35 PM
__
Edison.
03-27-2008 05:36 PM
got it - i had the wrong default gateway - i removed this:
no ip default-gateway 10.10.11.2
thanks for looking - jerry
