03-27-2008 08:50 PM
At the time of integrating ACS with CWLMS 3.0 we are facing issue. Earlier we had ACS server version that got integrated successfully with CWLMS 3.0. But after upgrading to ACS 4.1 we are not able to do so.
All settings are done as per cisco document.
In ACS LMS Server AAA client, LMS server AAA server & LMS server AAA client setting is done.
I am attaching LMS screen shot.
Please advice.
Solved! Go to Solution.
03-30-2008 10:07 PM
Please post screenshots showing the LMS server properly defined as a TACACS+ client in ACS as well as screenshots showing the admin TCP port configuration on the ACS and your LMS ACS configuration screen.
03-27-2008 10:51 PM
03-28-2008 02:58 AM
I do have CWLMS 3.0.1 & ACS 4.1
I did the same as per ur suggestion. But it's not working.
Any other setting to be done!!!
03-30-2008 10:03 PM
Hi Friend,
did you doublechecked the proper setup of the LMS as aaa client??
If the LMS is already a aaa client: just try to delete the LMS entry and setup a new one.
Are there any hints in the log files of the ACS?
Best regards,
Frank
03-30-2008 10:07 PM
03-30-2008 11:38 PM
Thanx a lot...the problem is resolved...
