03-27-2008 09:23 PM - edited 07-03-2021 03:36 PM
Hi all,
I would like to get some advises and expertise to guide me on this issue. Since WLC supports Local EAP for LEAP or FAST, I would like to save some costs of implementing ACS by using the internal built Local EAP authenticator.
What is the maximum Clients size would be able to work simultaneously in stable condition?
Simulataneous meaning that in the worst scenario, all clients logging in at the same time.
03-27-2008 09:28 PM
The database size (defaults to 512) is where the user information is kept; and this database is shared with a few other things internally (such as any dynamic interfaces you'd create, for example). This can be increased to a maximum of 2048 from the CLI.
(WLC) >config database ?
size Configures the maximum number of entries in the database.
03-27-2008 09:33 PM
Thanks for your quick response on my doubts.
So, is it comfortable to have 200 clients logging into the WLC and authenticating using the Internal Local EAP at the same time without any problem?
Assuming that I might have 1 or 2 dynamic interfaces.
