03-27-2008 10:25 PM
hi,
We have a new ME-3400-24TS-A Switch.Its a 24 10/100 Mbps switch.But when we connect the two PCs on its any of the two ports ,they are not pinging to each other.Both the PCs are in the same Network.
basic switching is not happening.Kindly help me!!The IOS version is :S340XBT-12225SEG
Cisco ME 340X SERIES IOS METRO BASE W/O CRYPTO TAR
03-29-2008 01:12 AM
by default ME 34xx / ME 24xx switch's ports are in set port type "uni". change port type to "nni".
Saiful
04-07-2008 09:43 PM
Thanks,but only 8 ports in one time can be made "NNI".
PLease help!
04-07-2008 10:53 PM
The ports in the same vlan don't do local switching per default on a ME3400. You have to enable local switching for a vlan with the commands "vlan xxx" and "uni-vlan community".
But, only 8 ports can be in the same vlan. So, maybe you have choose the wrong switch if you need a normal L2 switch. Normally, in Metro Ethernet you don't want local switching between user ports.
I hop this helps. Please rate all posts.
Cheers
Rene
