Easy VPN tunnel issue
I have 4 - 871's running 12.4(T8) that connect to an ASA running 8.x code utilizing EasyVPN. The problem is that 2 of the 871's connect and pass traffic without issue but the other 2 connect only for about 5 minutes. The configuration are all the same aside from ip's. I'm running the EasyVPN's in network extension mode. The weird thing is that they can pass traffic for about 5 minutes but following that they can not. ISAKMP and IPSEC stay connected and all appears as though it should be working but it doesn't.
871 config.
ip dhcp excluded-address 10.10.106.1
ip dhcp pool POOL1
import all
network 10.10.106.0 255.255.255.0
default-router 10.10.106.1
dns-server 10.10.14.51 10.10.14.53
netbios-name-server 10.10.14.10
domain-name microchip.com
lease 3
crypto ipsec client ezvpn hw-client
connect auto
group EasyVPNGroup key xxxxxx
mode network-extension
peer x.x.x.x
username mchp_easyvpn password xxxxxx
xauth userid mode local
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp client-id FastEthernet4
ip virtual-reassembly
duplex auto
speed auto
interface Vlan1
description LAN
ip address 10.10.106.1 255.255.255.0
ip tcp adjust-mss 1400
crypto ipsec client ezvpn hw-client inside
ASA: I created an EasyVPNGroup.
group-policy EasyVPNGrpPolicy internal
group-policy EasyVPNGrpPolicy attributes
vpn-simultaneous-logins 10
vpn-idle-timeout none
vpn-session-timeout none
vpn-tunnel-protocol IPSec
password-storage enable
ip-comp disable
re-xauth disable
pfs enable
ipsec-udp disable
ipsec-udp-port 10000
nem enable
no nat's and routes are all setup and working.
Just curious if anyone has had a similiar issues or any thoughts would be appreciated.
