Jon Marshall Fri, 03/28/2008 - 03:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Your crypto map access-lists don't match ie.
pix.txt
access-list bsns_out permit ip 14.1.0.0 255.255.255.0 10.20.0.0 255.255.255.0
access-list bsns_out permit ip 14.1.0.0 255.255.255.0 192.168.1.0 255.255.255.0
pixe.txt
access-list bsns_out permit ip 10.20.0.0 255.255.255.0 14.1.0.0 255.255.255.0
access-list bsns_out permit ip 10.20.0.0 255.255.255.0 14.2.0.0 255.255.255.0
These should match and you will need to ensure that your nonat access-lists match this as well.
Jon
danilomario Fri, 03/28/2008 - 03:33
Sorry why don't match ?
pix.txt
14.1.0.0 is internal lan
10.20.0.0 is external lan (destination)
192.168.1.0 is outside int of pixe.txt
pixe.txt
10.20.0.0 is internal lan
14.1.0.0 is external lan (destination)
14.2.0.0 is outside int of pix.txt
Jon Marshall Fri, 03/28/2008 - 03:57
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
They don't match because crypto access-lists should just be the reverse of each so
update you access-lists as follows
pix.txt
access-list bsns_out permit ip 14.2.0.0 255.255.255.0 10.20.0.0 255.255.255.0
pixe.txt
access-list bsns_out permit ip 192.168.1.0 255.255.255.0 14.1.0.0 255.255.255.0
Also where are you connecting from/to when it works and when it doesn't work ?
Jon
