Cisco vpn client and actividentity key with certificate not working in vist
Mar 28th, 2008
Is there any version of cisco vpn client that works vith windows vista(32bit) and Actividentity Smart Card When Using Certificates.
i-kendall Sun, 03/30/2008 - 08:04
You do not say what version of the client you are using. Download, or purchase, the latest version which works under Vista (there is one newer, but it is Beta at the moment). I don't know if it works with Actividentity, but if a previous client did on XP then it is likely it will work with this one.
