Presence and LCS 2005
Mar 28th, 2008
I have a questions a would like to confirm. Do I need Live Communications Enterprise Edition to enable the intregation with Presence? I have the LCS 2005 SP1 standard version and the Options for telephony do not seem to be available from LCS. All documentation points to Enterprise but I would like to confirm.
Armando
Tommer Catlin Fri, 03/28/2008 - 10:56
I would think any version will work. It is simply forwarding SIP information to a trunk to presence. (and vice versa)
aramos17428 Sat, 03/29/2008 - 07:08
I think you are right. I got confused since the MOC client had some of the options gray out and could not enable. After using the policy domain settings for the MOC client I was able to change the settings to enabled, but I'm still working on getting this to work with CM and Presence. I will provide an update.
Administrative Templates
Microsoft Office Communicator Policy Settings/Microsoft Office Communicator Feature Policies
Policy Setting
Telephony Mode Enabled
TelephonyMode 3 = Dual Mode
If you don;t have the policy listed you will have to open it from the admin file becuaes whne they did the install they did not choose telephony
http://www.petri.co.il/adding_new_administrative_templates_to_gpo.htm.
Armando
