03-28-2008 05:38 AM - edited 03-05-2019 10:02 PM
According to this report:
It stated that the Cisco 3845 can push 45Mbps VPN traffics. If that is true,
according to my diagram, I can push 45mbps of ftp traffic across the IPSec
VPN tunnel between the checkpoint
firewall and the Cisco 3845, correct?
I am not seeing anywhere near that.
Can anyone confirm this? Thanks.
03-28-2008 06:21 AM
You have 45Mbps P2P link between CP NGX and 3845? Your diagram show that both connected to internet, there is no end-to-end QoS guarantee in the internet.
If you have that bandwidth end-to-end, try using AES rather than 3DES.
Dandy
03-28-2008 06:38 AM
I used the Internet as an example. I have an
OC-3 P2P between the Checkpoint firewall and
the Cisco 3845. Furthermore, I am using
AES-128/sha-1 with DH group 5.
I am not seeing the throughput anywhere
near 45Mbps as the document claimed.
CCIE Security
