Need suggestion for IP contact center
Mar 28th, 2008
Hi All,
We have a call center environment, which has around 100 users,we are cuurently using Cisco Call manager version 4.0 (Windows based.However we would like increase the user count in the near future,Moreover we want to monitor
Agent status ?
measure the percentage of calls abandoned?
Average time to pickup a phone?
Longest wait time?
Current call Queue status ?
My question is, do i need to purchase IPCC ?or can we just upgrade the call Manager?
Please provide your valuable inputs.
Krish
lpezj Fri, 03/28/2008 - 05:57
  • Gold, 750 points or more
Krish,
To get those monitor statistics you will need to purchase IPCC (Express or Enterprise). In the case that you want to monitor the 100 users, they would be all agents and use the agent application. If someone that you want to monitor is put of IPCC you can not get all the statistics that you have said in your question.
Depending on your needs you can purcahse IPCC Express or Enterpise.
Hope this helps,
Juan Luis
gopikrish Sun, 03/30/2008 - 07:34
Hi Juan,
Thanks for your reply, Do i need to upgrade my call manager appliance from (ver 4.0 windows based)or i can keep using the existing one
does the IPCC is compatable with ver 4.0 ? Please suggest..
rkiamil Sun, 03/30/2008 - 08:30
How are you running a call center right now with Call Mnaager? Are you using Call Manager hunt groups? or do you have a 3rd party call center product?
