JTAPI Call Transfer
Mar 28th, 2008
I will try to explain the best i can.
CCM 4.2
IPCC 4.04(140)
I have a call recording application and i am currently recording calls for the IPCC agents. However when a call is trasfer to an aget via IPCC JTAPI the recording system shows the caller ID as the JTAPI extension instead of the actual caller. I would like to know if i check the box in CCM under the JTAPI directory numbers for "Forwarded Call Information Display">"Redirected Number" if this may stop that from happening?
ivillegas Thu, 04/03/2008 - 09:48
You will have to use Route Point to forward the Original Caller ID. Follow these steps 1) A calls B ,
2) JTAPI app intercepts the call and CTI Port accepts the call , 3) CTI Port route the call to a Route Point
4) Route Point redirects the call to C with modifying calling number as A
