dial-peer voip session target ras remove secondary dialtone
Mar 28th, 2008
i have a pri circuit that contains the number NNX-XXX-7599.
i configured the pri , dial-peers.
the 7599 number is my meeting place 8106 server, registered to gatekeeper on the same router (3745) as the pri.
i am getting secondary dialtone.
when i dial the number from the co i get dial tone and have to enter hte last 4 digits again then the call connects
a cisco white paper says to add direct-inward-dial. this command is not available with dial-peer voice voip.
how can i get this number to connect directly through.
thanks for any help
Jeff
dial-peer voice 7599 voip
destination-pattern 7599
session target ras
dtmf-relay h245-alphanumeric
codec g711ulaw
ip qos dscp cs5 media
ip qos dscp cs3 signaling
controller T1 2/0
framing esf
linecode b8zs
pri-group timeslots 1-24
description SBC BL PRI2 H.323
interface Serial2/0:23
no ip address
no logging event link-status
isdn switch-type primary-ni
isdn incoming-voice voice
no cdp enable
jmize Mon, 03/31/2008 - 08:07
HI
I have a combination of MGCP and H.323 trunks
the trunk i am working with is 2/0
here is the config
thanks for any ideas
attached is the config
adham2005 Mon, 03/31/2008 - 17:22
You need to add a "POTS" dial-peer for the 2/0:23 Voice port matching somthing like this
dial-peer voice 455 pots
incoming called-num 7599 ! for example
direct-inward-direct
port 2/0:23
jmize Tue, 04/01/2008 - 04:59
Not sure that will work.
the 7599 number is coming in on 2/0:23 and needs to point to RAS the gatekeeper.
but i will give it a try.
thanks
