Mar 28th, 2008
does modular router 7206 can support 802.1d - Spanning-Tree, I don't know what is the reason my client want this, but can it support this proto?
mattcalderon Fri, 03/28/2008 - 08:02
Yes it does support STP if the port is a L2 port.
Here are 2 adapters PA-2FE-TX, and PA-2FE-FX
asentchernaev Fri, 03/28/2008 - 08:22
You mean that because this is modular router, you can put as module card with L2 ports, which will be used as internal switch, and then STP will be used in this switch?
