host unable to connect after DHCP exlcusion
Answered Question
Mar 28th, 2008
One of the users asked that they be given a static IP for some apllications they are running on their desktop.
They had the dynamically assigned IP of 192.168.22.32
I excluded them from the dhcp pool, than
statically configured their pc to the excluded address...now they are unable to connect to the network...does this make sense?
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.10.10.1
ip dhcp excluded-address 192.168.22.1 192.168.22.10
ip dhcp excluded-address 192.168.22.32
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip dhcp pool sdm-pool1
import all
network 192.168.22.0 255.255.255.0
dns-server 192.168.1.27
default-router 192.168.22.1
netbios-name-server 192.168.119.2 192.168.117.15
netbios-node-type h-node
Correct Answer by Edison Ortiz about 8 years 12 months ago
Did they manually enter 192.168.22.32 and DNS 192.168.1.27 and default gateway 192.168.22.1 ?
Lots of thing are forgotten when manually entering IP information in a host device. That's the reason DHCP is the preferred choice for handing out IP address.
You could've configured this device with a static mapping in your DHCP server instead of trusting them to enter the correct information.
Please see:
http://www.cisco.com/en/US/docs/ios/12_4/ip_addr/configuration/guide/hipdhcps.html#wp1114732
HTH,
__
Edison.
Overall Rating: 5 (1 ratings)
Correct Answer
Edison Ortiz Fri, 03/28/2008 - 08:56
  • Hall of Fame,
    Founding Member
Please see:
HTH,
__
Edison.
nygenxny123 Fri, 03/28/2008 - 09:49
Thx Edison!
and yes..i shouldnt have trusted them..
turns our they had the subnet mask wrong.
Ill review the doc to avoid further issues
