DMVPN qos tunnel configuration
ramiro.espinoza
im trying to set up qos for voice but the tunnel interface doesnt support
class based wheighted fair is there another way to protirize voice traffice on the tunnel?
14 Replies 14
Marcin Zgola
Level 4
Level 4
this is an example i am connecting to internet via multinlink, and this is a hub for my 85 dmvpn sites. qos works fine.
class-map match-any VOICE
match ip dscp ef
class-map match-any CALL-SETUP
match ip dscp af31
match ip dscp cs3
policy-map VOICE
class CALL-SETUP
bandwidth percent 3
class VOICE
bandwidth percent 40
class class-default
fair-queue
interface Tunnel1
bandwidth 1000
ip address 192.168.20.1 255.255.252.0
no ip redirects
ip mtu 1340
no ip next-hop-self eigrp 100
ip pim sparse-dense-mode
ip nhrp authentication dmvpn
ip nhrp map multicast dynamic
ip nhrp network-id 100
ip nhrp holdtime 300
no ip split-horizon eigrp 100
ip summary-address eigrp 100 10.0.0.0 255.0.0.0 5
no ip mroute-cache
delay 1000
qos pre-classify
cdp enable
tunnel source Loopback1
tunnel mode gre multipoint
tunnel key 1000
tunnel path-mtu-discovery
tunnel protection ipsec profile xxxxx
interface Multilink1
ip address xxxxxx yyyyyyyy
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
rate-limit input access-group 160 64000 8000 8000 conform-action transmit exceed-action drop
ip route-cache flow
load-interval 30
ppp multilink
ppp multilink fragment delay 20
ppp multilink interleave
ppp multilink group 1
ppp multilink multiclass
crypto map ipsecvpn
service-policy output VOICE
CCIE 18676
i got it to work but i did some different,
i used auto qos on the wan interface of the spoke route, then i did qos prequalify on the tunnel interface and on the hub i did qos prequalify only on the tunnel interface, would this work ok? i have another question i probably gonna have 5 spokes now why would i need a multilink and a tunnel interface instead of just the tunnul interface?
multilink is just how i connect to internet, you can have serial or fa0/0 or gi0/0, this does not matter.
CCIE 18676
is there a way that i can use active directory or the IAS (radius) server to autehnticate users using webvpn?
yes using aaa create authentication for network
aaa authentication network group radius
and point to your IAS server.
CCIE 18676
do you have an exaple configuration i tried that and i cant seem to get it to work
looks like i still need you help, here is the policy for the hub qos prequlify is being apply to interface tunnel 0, the policy map below is being apply to wan link
****when im uploading, the phone still garbled
what else do i need to configure?
class-map match-all avaya-traffic
match ip dscp af31
class-map match-all avaya-voice
match ip dscp ef
policy-map DMVPN
class avaya-voice
priority percent 33
class avaya-traffic
bandwidth percent 10
class class-default
fair-queue
interface Tunnel0
description DMVPN Interface for remote access
bandwidth 1000
ip address 10.0.0.1 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication westmont
ip nhrp network-id 99
ip nhrp cache non-authoritative
ip tcp adjust-mss 1360
delay 1000
qos pre-classify
tunnel source GigabitEthernet0/0
tunnel key 100000
tunnel protection ipsec profile vpnippro
interface GigabitEthernet0/0
description Public Network Interface$ETH-LAN$
ip address 38.113.137.150 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
service-policy output DMVPN
======Spoke==================
samething on this one to0
class-map match-any Voice
match ip dscp ef
policy-map voip
class Voice
bandwidth 128
random-detect dscp-based
class class-default
fair-queue
nterface Tunnel0
bandwidth 100
ip address 10.0.0.2 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.0.0.1 38.113.137.150
ip nhrp map multicast 38.113.137.150
ip nhrp nhs 10.0.0.1
delay 1000
qos pre-classify
tunnel source FastEthernet4
tunnel key 100000
interface FastEthernet4
bandwidth 384
bandwidth receive 768
ip address dhcp
ip nat outside
duplex auto
speed auto
auto discovery qos trust
service-policy output voip
+++++++++HUB++++++++++++++++
y output: DMVPN
Class-map: avaya-voice (match-all)
2233 packets, 795686 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: ip dscp ef (46)
Queueing
Strict Priority
Output Queue: Conversation 264
Bandwidth 33 (%)
Bandwidth 330000 (kbps) Burst 8250000 (Bytes)
(pkts matched/bytes matched) 0/0
(total drops/bytes drops) 0/0
Class-map: avaya-traffic (match-all)
2857 packets, 950126 bytes
Match: ip dscp af31 (26)
Queueing
Output Queue: Conversation 265
Bandwidth 10 (%)
Bandwidth 100000 (kbps)Max Threshold 64 (packets)
(depth/total drops/no-buffer drops) 0/0/0
Class-map: class-default (match-any)
204497 packets, 62183144 bytes
5 minute offered rate 1000 bps, drop rate 0 bps
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
ok, your hub is souring out of gig interface. qos will never work until this interface is utilized at 100%. what kind of internet connection do you have, lets say if your upload in only 5meg. this is what i would do.
match ip dscp af31
match ip dscp ef
policy-map DMVPN
class avaya-voice
priority percent 33
class avaya-traffic
class class-default
fair-queue
policy-map INTERNET
class class-default
shape average 5000000 50000
fair-queue
random-detect
service-policy DMVPN
fair-queue
int g0/0
service-policy output INTERNET
this will shape the traffic to 5meg, and if 5mg is at 100% then qos will kick in, you can always adjust 500000 to what ever your upload speed is.
hope this helps
CCIE 18676
do i need to do anything on the spoke, the phone is on he spokes network
same concept, i noticed your spoke connects via fastethernet, so again qos will not work if traffic is not at 100% of 100mg.
CCIE 18676
i decided to migrate to GETVPN now can i having a couple of issue can you send me an exaple config with details and qos
nevermind GETVPN doesnt support NAT, weird but oh well
ramiro.espinoza
ramiro.espinoza
