IOS SLB Sticky duration parameter
Mar 28th, 2008
When configuring the IOS SLB sticky feature in the virtual server is the duration parameter that gets defined in seconds the value that the client connection timeout after being idle for x seconds that get defined in the duration parameter?
Or is this duration parameter the value when the sticky expires and moves to another real server?
My goal is to always have that persistence connection to the real server once the connection is established
Thank you,
JR
MW20082008 Fri, 03/28/2008 - 10:00
The sticky connection paramater ensures that the same client hits the same real server for the time you configure.
juan-ruiz Fri, 03/28/2008 - 11:01
so if I configure the duration in 1200 seconds once the 1200 seconds are up the client gets dropped or sent to another real server?
THANKS for the reply
