OWA not accessible after setting up vpn through ASA 5505
Mar 28th, 2008
I have a client that is running Win2003 Server R2 with Exchange Server 2003. OWA was setup and clients could connect to their exchange mailbox from the internet with no problems.
We recently configured vpn on the ASA 5505 and now no-one can connect to OWA since that time.
Here is what I have for a configuration.
Any thoughts?
i-kendall Fri, 03/28/2008 - 16:02
I thought OWA uses tcp port 80 by default, or 443 if you use https. Ignore the rest if this fact is wrong. Otherwise ...
In your config there is nothing to allow the www traffic in the access-list outside_access_in
access-list outside_access_in extended permit tcp any interface outside eq 80
and no static nat for this
static (inside,outside) tcp interface 80 80 netmask
I think these must have got deleted when you made the other changes ? Hope this helps.
