Internet is Down! Urgent
Mar 28th, 2008
I don't know why last night I turn on my pc and can not connect to the Internet. When I ipconfig/all it is showing my ISP Connection-specific DNS Suffix, and DNS; I tried to ping, but it is not. I have another machine it is showing 169.x.x.x. I tried ipconfig/release and renew, but till showing 169.x.x.x
I can not login SDM or just type in default gateway on my IE.
I can sign on my router, but when I enable; I do not have password setting on this feature before.
Does it issue relate to NAT (trust inbound and outbound) for Vlan, FE1, or FE0 setting?
Please input!
techtips03 Fri, 03/28/2008 - 12:48
Hi Nguyen
Firstly I see you are not connected to the network as you are not getting an IP address.
Is your router acting as DHCP?
Do you have a switch in between the PC and the router?
Can you ping the router when you connect your PC directly to the router?
Assign a static IP and try to ping the router and yahoo.com or with its ip address
