Switchport trunks on end devices/ switchport trunk native.
rwamstutz
All, I have this config I inherited: To me, this config looks out of wack. These ports are end user ports for some machines we have on the shop floor. Their are no phone attached to the ports configured as below. I do plan on removing the qos, and srr-queue commands. My question is, what is the point of the switchport trunk commands? Are end user ports to be trunked?
What does the Switchport trunk native, do for me?
VLAN 205 is a bogus VLAN. Is it needed?
THANK YOU FOR YOUR HELP.
interface FastEthernet1/0/3
switchport access vlan 200
switchport trunk native vlan 205
switchport mode dynamic desirable
switchport voice vlan 246
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
ankbhasi
Hi Friend,
You can remove all trunk related commands if you are sure this ports if for end user host. Also change "switchport mode dynamic desirable" to "switchport mode access".
Sometimes even when servers are connected on switchport they understand dot1q tags and is the reason switchport may be configured for trunk but as you mentioned they are user ports you can simply remove trunk configuration.
Ankur
*Pls rate all helpfull post
padramas
Hello Rob,
As you have mentioned the role of the ports and devices connected to it, the above configuration can be stripped down to basic configuration.
switchport access vlan XX
Regarding your questions on switchport trunk,
a port has to be configured as trunk when it has to carry multiple vlan traffic and to differentiate traffic we define encapsulation method.
Trunk native is used to identify the vlan traffic for which frames will not be tagged/encapsulated.
Padmanabhan
