Diego Vargas Fri, 03/28/2008 - 11:04
Matt,
You lost the password used to keep the file secure on the CSS or the passphrase (password) used to encrypt the certificate file (PKCS12 or Encrypted-PEM)?
Diego M
matt.s Fri, 03/28/2008 - 11:19
The password to keep the file secure.
Here are the commands I'm using...
clear ssl file name.com-cert.cer "password"
copy ssl ftp default export name.com-cert.cer "password"
MaTT
Diego Vargas Fri, 03/28/2008 - 11:26
Matt, so you want to import a new certificate on the CSS to replace an expired?
Or you need to export a CSS certificate to installed on another box?
You cannot take the SSL cert out of the CSS if you lost the password, no way around.
If you need to import a new certificate to replace the old, just import it and named different than older and replace it on the ssl-proxy-list.
Please let me know.
matt.s Fri, 03/28/2008 - 11:43
Yes, import a new certificate on the CSS to replace an expired.
I will import new cert with different name and update the proxy-list.
MaTT
I will let you know how it goes tonight.
