Hi All,
In my Pix firewall(535) I can easily check the connection/Traffic flowing through it with the SHOW CONN command. I am looking for this type of command in router (2800/3800 Sr.). Can any body tell me which command should I use to check the traffic flowing through the router (source_ip to dest_ip). As I am not using the nat in the router so I can not get this information with the show translate command.
Thanks in advance.
Adnan
