No More MTP Resources available?
Mar 28th, 2008
  • Green, 3000 points or more
Hello! I have CUCM 6.01 using SOFTWARE conference bridge. Everything is configured correctly, registered, running, etc. But when i try to add more than 3 people to a conference call, it drops or busy signal. Software is pretty straight forward, so Im not sure why its failing. My codecs are all G711, same region, same location, etc. Meet-Me max is set to 8 (default is 4)
gogasca Fri, 03/28/2008 - 13:46
Which Phones any IP Communicator involved?
Using under Audio Optimize for Low Bandwith....?
Do you have the CCM detailed trace?
Tommer Catlin Fri, 03/28/2008 - 13:48
No communicator involved
Audio is unlimited at this site.
What type of traces?
Tommer Catlin Fri, 03/28/2008 - 14:18
Yeah, Im not sure whats going, but now its working. I did restart the CFB on Sub and Pub. Automagically it started working again. odd.
rathish_ram Fri, 03/28/2008 - 14:19
Simple. Please have the value changed on your service parameters, change "Maximum Ad Hoc" value to suit your need. Also since you are using g711, prioritize your software resource on Media Resources List. This should help.
