Firewall Configuration for huge network
Mar 28th, 2008
Hi, In my organisation there are 5 Vlans and all are configured on switch and this is a L3 switch and each one is connected L2 switch and I have make multipal V-lan on L2 switch as well and I have make all route entries on L3 Switch. In this scneario Do i need to do any setting on firewall to access the internet all Vlan machine.
JORGE RODRIGUEZ Fri, 03/28/2008 - 14:37
  • Green, 3000 points or more
As long you have in L3 switch default route pointing to ASA inside interface, AND, that in asa you have global(outside) 1 interface nat(inside) 1 0 0 plust a default route, all your L3 SVI subnets should get outbound internet access.
Rgds
Jorge
JORGE RODRIGUEZ Fri, 03/28/2008 - 14:41
Glad I could help, if any problems let us know.
Rgds
Jorge
Pls rate any helpful post if it helps
