Lab access to Production Directory
Mar 28th, 2008
Just curious.
Is it possible for a "lab" call manager (5.04) to use the production directory data (3.3.3 sr4) for the corporate directory access? If so how do I configure CCM 5 to do this. I just want to display the corporate directory, not perform any other integration between the systems.
Jaime Valencia Fri, 03/28/2008 - 20:26
you can try changing the enterprise parameter for the directories URL to the same one as the other server and try it
javalenc
if this helps, please rate
gogasca Fri, 03/28/2008 - 22:55
That will involve having the same Devices that you have defined in 5.0.4 in 3.3(3) since our URL pass DeviceName as parameter...
