NM-CUE vs. NM-CUE-EC
Mar 28th, 2008
Specs indicate that the NM-CUE and NM-CUE-EC have the same 20GB hard drive. I was just wondering why is one 100 hours of storage and the other 300 hours of storage if both have the same hard drive capacity?
If I wanted to upgrade my NM-CUE to provide 300 hours how do I do that?
Is their a way to view the filesystem inside the CUE CLI?
Thanks for the help.
Paolo Bevilacqua Sat, 03/29/2008 - 03:20
Possibly the -EC compresses storage?
Access to filesystem is not supported. If you want to try something, mount the disk an a system.
hope this helps, please rate post if it does!
