Voice Interface on serial1/0:15 Status Shows reset
Answered Question
Mar 29th, 2008
  • Cisco Designated VIP,
    2017 IP Telephony
I am having a very weird problem on E1-pri card on NM-1CE1T1-PRI module.
After I configured the pri-group timeslots 1-31,16...I noticed the associated voice-port 1/0:15 was not created. Interface serial 1/0:15 was created.
When I do a sh ip int br...The ints1/0:15 status shows reset....
as shown below:
Serial1/0:0 unassigned YES unset reset down
Serial1/0:1 unassigned YES unset reset down
Serial1/0:2 unassigned YES unset reset down
Serial1/0:3 unassigned YES unset reset down
Serial1/0:4 unassigned YES unset reset down
Serial1/0:5 unassigned YES unset reset down
Serial1/0:6 unassigned YES unset reset down
Serial1/0:7 unassigned YES unset reset down
Serial1/0:15 unassigned YES unset reset down
My config looks like this...
card type e1 1
network-clock-participate slot 1
isdn switch-type primary-net5
Controller e1 1/0
interface Serial1/0:15
encapsulation hdlc
no ip address
isdn incoming-voice voice
no cdp enable
Correct Answer by Paolo Bevilacqua about 8 years 12 months ago
NM-1CE1T1-PRI does not support voice.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Sat, 03/29/2008 - 03:01
  • Hall of Fame,
    Founding Member
Ayodeji Okanlawon Sat, 03/29/2008 - 04:33
    2017 IP Telephony
Thank you!!!!!!!!
Paolo Bevilacqua Sat, 03/29/2008 - 11:10
  • Hall of Fame,
    Founding Member
You're welcome. Thanks for the nice rating and good luck!
