L2L VPN Tunnel Problem
Mar 29th, 2008
I have a lan-to-lan tunnel with my partners. They are using PIX Firewall and on my end it is VPNC3060. The problem is the tunnel is up and I am getting his ping/telnet response in my VPNC. From there end they are suppose to access one of my Server that is behind my VPNC - but they are not able to.
On the other hand - I am also not able to get his lan ip by traceroute from my end - the traceroute stops in my VPNC.
I have checked both end LAN (local & Remote lan) - both are same.
Before my VPNC - there is no NATing - it is directly going to the Internet.
Kindly let me know - what might I can check to resolve the problem.
Adnan
