Quality Monitoring Issue
I have installed a QM server with UCCX 5.0. I have also installed client applications on PCs. The recording is made and stored locally on PCs in the folder : C:\Program Files\Common Files\SQM\recordings\daily.
The problem is that I don't find the files in the server and when using the desktop application for the supervisor/manager, I found contacts but not the recordings.
What may be the issue?
joshw Tue, 04/15/2008 - 12:28
Sounds like the metadata is uploaded to the server but not the audio recordings. Make sure the upload time is set on the workflow in administrator.
cornel.chirculete Tue, 09/09/2008 - 12:06
I have mainly the same issue. I can see some RAW files stored on the agent PC but not on the server. I have checked everything, time, archiving. What about that proxy that I can see on the agent pc and on the server? Should I configure that in some way? Where can I see the reason fot this copy failure?
Thank you for any suggestion.
epekou Wed, 10/15/2008 - 04:12
Do you have any update on this issue? I have the same problem.
thanks,
Evi.
cornel.chirculete Thu, 10/16/2008 - 00:24
No, I didn't resolve the issue. I am using the IPCC recording for the moment. Bu really, I think I should open a case. The hard part is that my istallation is remote...
Very "nice" software from Cisco anyway :)
Nicolas Mansour Sun, 10/26/2008 - 13:41
Hi guys,
I have the same setup but my problem is that I can't see the recorded files even on the desktop in raw format.
As a tip for the uploading, you must configure QM to have (in AD mode or local mode) the username and password of the agent desktop. The QM will need these credentials to upload the files.
Best documentation i've seen sofar ;)
