Not able to connect from outside IP
Mar 29th, 2008
Hi, the Firewall configuration is attached
When I try to access by remote desktop from outside IP to 196.44.242.51 Server (vrw-appdb-001) then I am not able to connect. Please check above config if you find anything wrong then please let me know.
chickman@pronet... Sat, 03/29/2008 - 08:19
Ray,
Am I understanding right, you are not able to Remote Desktop (RDP) into the network from APPDB?
***Edit***
I see what you're saying now.
chickman@pronet... Sat, 03/29/2008 - 08:23
Ray,
I am able to connect to the said server via Remote Desktop just fine. The problem is possibly on your side.
On a security note.. I would suggest an alternate approach to allowing access like this. You might want to think about possibly a VPN account and using that to access these devices. Leaving them open to the world over these protocols is extremely dangerous.
Anyway, best of luck!
tejas_2207 Sun, 04/06/2008 - 08:51
hi there
U r using a wrong command for connecting the outside
access-list vrw-vpn-001_splitTunnelAcl standard permit 192.168.50.0 0.0.0.255
access-list vrw-vpn-001_splitTunnelAcl standard permit 192.168.51.0 0.0.0.255
here u use a subnet mask u have to use a wild card mask
try this command once
thanks
