CME New install incoming calls ok outgoing call issue
Mar 29th, 2008
Hi All, not sure why I can't call out the config is attached and would appreciate help.
Incoming calls work fine, so I guess the ISDN config is fine. When I dial the following local number: 902920nnnnnn (n = number between 1-9) unknown number is displayed on the phone, I can't see why the dial peer is not matched. I'm thinking there is an issue with other parts of the config.
Craig.
paolo bevilacqua Sat, 03/29/2008 - 08:30
  • Hall of Fame,
    Founding Member
Hi, your only active DP for call, tries to match 920 followed by six digits, it that right ?
If you want to see why that fails, enable "debug isdn q931" with "term mon".
craig.corbett Sat, 03/29/2008 - 09:03
Sorry that's right I'm trying to dial a local number 20......
Would I need forward digits 8 and not 6?
craig.corbett Sat, 03/29/2008 - 09:08
I guess thats what the prefix 20 does so forward digits 6 should be ok?
paolo bevilacqua Sat, 03/29/2008 - 09:43
  • Hall of Fame,
    Founding Member
Either use forward-digits 8, OR prefix 20.
In many countries it's also possible NOT to use any prefix digit for external calls, users like that very much because it's like calling from home, just make sure all the internal extensions begin with a digit not used by your contry dialplan.
craig.corbett Sat, 03/29/2008 - 10:43
I see.
I'll be able to run the debug on Monday, I'll post back with the results.
Craig.
craig.corbett Mon, 03/31/2008 - 06:34
Hi, this is the debug output:
core(config-dial-peer)#
Mar 31 13:08:16.227: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Calling num .
Mar 31 13:08:16.227: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x0 0x0, Called num 01443123456 <
Mar 31 13:08:16.227: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8 callref = 0x01
Bearer Capability i = 0x8090
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x81
Preferred, B1
Progress Ind i = 0x8183 - Origination address is non-ISDN
Calling Party Number i = 0x0080, '.'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '01443123456' <
Mar 31 13:08:16.307: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x81
Cause i = 0x82E4 - Invalid information element contents
core-multimedia-cme(config-dial-peer)#
paolo bevilacqua Mon, 03/31/2008 - 06:47
  • Hall of Fame,
    Founding Member
Possibly the switch doesn't like the empty calling number. Try removing it altogether, under DP: "clid strip".
paolo bevilacqua Mon, 03/31/2008 - 08:22
  • Hall of Fame,
    Founding Member
Honestly I can't remember which type/plan si needed in the UK. Take a trace for an incoming call and so we can set them the same.
craig.corbett Tue, 04/01/2008 - 00:37
Hi this issue is now resolved, I removed “bearer-cap Speech” from voice-port 0/1/0 and that was it.
paolo bevilacqua Tue, 04/01/2008 - 04:05
  • Hall of Fame,
    Founding Member
Yep.. UK is special in that. Other countries don't care.
craig.corbett Tue, 04/01/2008 - 05:22
I have another question relating to my configuration and was wondering if you can help? I have extension 500 shared with two phones. Extension 500 also has a voicemail box. When an outside call comes in both phones will ring, if no one answers a call a voicemail is left, but the voicemail lams on two phones are not illuminated.
