Cannot Telnet to ASA in VPN tunnel.
Mar 29th, 2008
Once I am in VPN tunnel, I can't Ping or Telnet to the ASA using Inside interface IP.
Below is the partial configuration:
telnet 10.17.70.0 255.255.255.0 Outside
telnet 172.17.0.0 255.255.0.0 Inside
telnet timeout 10
ssh 172.17.0.0 255.255.0.0 Inside
ssh timeout 60
ssh version 1
console timeout 0
management-access Inside
fortis123 Sat, 03/29/2008 - 08:18
You cannot Telnet to ASA outside i/f. SSH is the way to go. Please check the link...
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008069bf1b.shtml
Also, for telnet to india IP via tunnel... certain train of IOS has Bug in that. I have seen that information in 'Security' section on Netpro. Please check that. More stable is 7.2(3).
PING--> make sure you have access-lists allows that.
hth
MS
